ArcGIS.Desktop.Mapping Namespace / Layer Class / SetMinDistance Method
Minimum distance.
    Sets the minimum distance (in meter) at which the layer is visible in a 3D scene or globe view. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetMinDistance( _
       ByVal minDistance As Double _
    public void SetMinDistance(
       double minDistance
    Parameters
    minDistance
    Minimum distance.
    Exceptions
    ExceptionDescription
    Requirements
