Parameters
- isVisible
- Visible.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
if (!layer.IsVisible)
layer.SetVisibility(true);
if (layer is FeatureLayer featureLayerToChange)
if (!featureLayer.IsEditable)
featureLayer.SetEditable(true);
if (!featureLayer.IsSnappable)
featureLayer.SetSnappable(true);
// Note: call within QueuedTask.Run()
var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
var createParam = new FeatureLayerCreationParams(new Uri(url))
IsVisible = false //turned off by default
streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(createParam, map);
//or use "original" create layer (will be visible by default)
Uri uri = new Uri(url);
streamLayer = LayerFactory.Instance.CreateLayer(uri, map) as StreamLayer;
streamLayer.SetVisibility(false);//turn off
