ArcGIS.Desktop.Mapping Namespace / LayerFactory Class
Members Example
    LayerFactory Class
    Provides static methods to create layers.
    Object Model
    LayerFactory ClassLayer ClassGroupLayer ClassILayerFactory Interface
    Syntax
    Public Class LayerFactory
       Implements ILayerFactory
    public class LayerFactory : ILayerFactory
    Example
    Create layer with create-params
        var flyrCreatnParam = new FeatureLayerCreationParams(new Uri(@"c:\data\world.gdb\cities"))
            Name = "World Cities",
            IsVisible = false,
            MinimumScale = 1000000,
            MaximumScale = 5000,
            DefinitionQuery = new DefinitionQuery(whereClause: "Population > 100000", name: "More than 100k"),
            RendererDefinition = new SimpleRendererDefinition()
                SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
           CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //Note: Needs QueuedTask to run
        var featureLayerWithParams = LayerFactory.Instance.CreateLayer<FeatureLayer>(flyrCreatnParam, map);
    Create FeatureLayer and add to Map using LayerCreationParams
        //Get the LayerDocument from a lyrx file
        var layerDoc = new LayerDocument(@"E:\Data\SDK\Default2DPointSymbols.lyrx");
        //Get the CIMLayerDocument from the LayerDocument and use it to create LayerCreationParams
        var createParams = new LayerCreationParams(layerDoc.GetCIMLayerDocument());
        //Create a FeatureLayer using the LayerCreationParams
        LayerFactory.Instance.CreateLayer<FeatureLayer>(createParams, MapView.Active.Map);
    Create FeatureLayer and set to not display in Map.
        //The catalog path of the feature layer to add to the map
        var featureClassUriVisibility = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
        //Define the Feature Layer's parameters.
        var layerParamsVisibility = new FeatureLayerCreationParams(featureClassUriVisibility)
            //Set visibility
            IsVisible = false,
        //Create the layer with the feature layer parameters and add it to the active map
        var createdFC = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParamsVisibility, MapView.Active.Map);
    Create FeatureLayer with a Renderer
        //Define a simple renderer to draw the Point US Cities feature class.
        var simpleRender = new SimpleRendererDefinition
            SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 4.0, SimpleMarkerStyle.Circle).MakeSymbolReference()
        var featureClassUri = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
        var layerParams = new FeatureLayerCreationParams(featureClassUri)
            //Set visibility
            IsVisible = true,
            //Set Renderer
            RendererDefinition = simpleRender,
        var createdFCWithRenderer = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
    Add MapNotes to the active map
        //Gets the collection of layer template packages installed with Pro for use with maps
        var items = MapView.Active.Map.LayerTemplatePackages;
        //Iterate through the collection of items to add each Map Note to the active map
        foreach (var item in items)
            //Create a parameter item for the map note
            var layer_params = new LayerCreationParams(item);
            layer_params.IsVisible = false;
            //Create a feature layer for the map note
            var layerCreated = LayerFactory.Instance.CreateLayer<Layer>(layer_params, MapView.Active.Map);
    Create a new SubTypeGroupLayer
              var subtypeGroupLayerCreateParam = new SubtypeGroupLayerCreationParams
                (new Uri(@"c:\data\SubtypeAndDomain.gdb\Fittings"));
              // Define Subtype layers
              var rendererDefn1 = new UniqueValueRendererDefinition(new List<string> { "type" });
              var renderDefn2 = new SimpleRendererDefinition()
              subtypeGroupLayerCreateParam.SubtypeLayers = new List<SubtypeFeatureLayerCreationParams>()
          //define first subtype layer with unique value renderer
          new SubtypeFeatureLayerCreationParams(new UniqueValueRendererDefinition(new List<string> { "type" }), 1),
          //define second subtype layer with simple symbol renderer
          new SubtypeFeatureLayerCreationParams(renderDefn2, 2)
              // Define additional parameters
              subtypeGroupLayerCreateParam.DefinitionQuery = new DefinitionQuery(whereClause: "Enabled = 1", name: "IsActive");
              subtypeGroupLayerCreateParam.IsVisible = true;
              subtypeGroupLayerCreateParam.MinimumScale = 50000;
              SubtypeGroupLayer subtypeGroupLayer2 = LayerFactory.Instance.CreateLayer<SubtypeGroupLayer>(
                            subtypeGroupLayerCreateParam, MapView.Active.Map);
    Create layer from a lyrx file
        //Note: Call within QueuedTask.Run()
        var lyrDocFromLyrxFile = new LayerDocument(@"d:\data\cities.lyrx");
        var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
        //modifying its renderer symbol to red
        var cimSimpleRenderer = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMSimpleRenderer;
        cimSimpleRenderer?.Symbol.Symbol.SetColor(new CIMRGBColor() { R = 255 });
        //optionally save the updates out as a file
        lyrDocFromLyrxFile.Save(@"c:\data\cities_red.lyrx");
        //get a json representation of the layer document and you want store away...
        var aJSONString = lyrDocFromLyrxFile.AsJson();
        //... and load it back when needed
        lyrDocFromLyrxFile.Load(aJSONString);
        //create a layer and add it to a map
        var lcp = new LayerCreationParams(cimLyrDoc);
        var lyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
    Add a WMS service
        // Create a connection to the WMS server
        var serverConnection = new CIMInternetServerConnection { URL = "URL of the WMS service" };
        var connection = new CIMWMSServiceConnection { ServerConnection = serverConnection };
        // Add a new layer to the map
        var layerParams = new LayerCreationParams(connection);
        var layerCreated = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
    Add a WFS Service
        CIMStandardDataConnection cIMStandardDataConnection = new CIMStandardDataConnection()
            WorkspaceConnectionString = @"SWAPXY=TRUE;SWAPXYFILTER=FALSE;URL=http://sampleserver6.arcgisonline.com/arcgis/services/SampleWorldCities/MapServer/WFSServer;VERSION=2.0.0",
            WorkspaceFactory = WorkspaceFactory.WFS,
            Dataset = "Continent",
            DatasetType = esriDatasetType.esriDTFeatureClass
        var layerPamsDC = new LayerCreationParams(cIMStandardDataConnection);
        Layer layerCreated = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerPamsDC, MapView.Active.Map);
    Create a query layer
        Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri(@"C:\Connections\mySDE.sde")));
        CIMSqlQueryDataConnection sqldc = new CIMSqlQueryDataConnection()
            WorkspaceConnectionString = geodatabase.GetConnectionString(),
            GeometryType = esriGeometryType.esriGeometryPolygon,
            OIDFields = "OBJECTID",
            Srid = "102008",
            SqlQuery = "select * from MySDE.dbo.STATES",
            Dataset = "States"
        var lcp = new LayerCreationParams(sqldc)
            Name = "States"
        FeatureLayer flyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
    Create a New Elevation Surface
        //Define a ServiceConnection to use for the new Elevation surface
            Anonymous = true,
            HideUserProperty = true,
            URL = "https://elevation.arcgis.com/arcgis/services"
        CIMAGSServiceConnection serviceConnection = new CIMAGSServiceConnection
            ObjectName = "WorldElevation/Terrain",
            ObjectType = "ImageServer",
            URL = "https://elevation.arcgis.com/arcgis/services/WorldElevation/Terrain/ImageServer",
        //Defines a new elevation source set to the CIMAGSServiceConnection defined above
        //Get the elevation surfaces defined in the map
        var listOfElevationSurfaces = map.GetElevationSurfaceLayers();
        //Add the new elevation surface
        var elevationLyrCreationParams = new ElevationLayerCreationParams(serviceConnection);
        //Note: needs to be called on the MCT
        var elevationSurface = LayerFactory.Instance.CreateLayer<ElevationSurfaceLayer>(
            elevationLyrCreationParams, map);
    Add an elevation source to an existing elevation surface layer
        ElevationSurfaceLayer surfaceLayer = null;
        // surfaceLayer could also be the ground layer
        string uri = "https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer";
        var createParams = new ElevationLayerCreationParams(new Uri(uri));
        createParams.Name = "Terrain 3D";
        var eleSourceLayer = LayerFactory.Instance.CreateLayer<Layer>(createParams, surfaceLayer);
    Create a raster layer with a new colorizer definition
        // Create a new stretch colorizer definition using default constructor.
        StretchColorizerDefinition stretchColorizerDef = new StretchColorizerDefinition();
        // Create a raster layer creation parameters object with the raster file path.
        var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri("rasterPath"))
            ColorizerDefinition = stretchColorizerDef,
            Name = "rasterLayerName",
            MapMemberIndex = 0
        // Create a raster layer using the colorizer definition created above.
        // Note: You can create a raster layer from a url, project item, or data connection.
        //Note: Run within a QueuedTask
        RasterLayer rasterLayerfromURL =
      LayerFactory.Instance.CreateLayer<RasterLayer>(rasterLayerCreationParams, map);
    Create a mosaic layer with a new colorizer definition
    // Create a new colorizer definition using default constructor.
        var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri("url"))
            Name = "layerRasterName",
            MapMemberIndex = 0
        // Create a mosaic layer using the colorizer definition created above.
        // Note: You can create a mosaic layer from a url, project item, or data connection.
        MosaicLayer newMosaicLayer = LayerFactory.Instance.CreateLayer<MosaicLayer>(rasterLayerCreationParams, map);
    Create an image service layer with a new colorizer definition
        var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri(url))
            Name = "RasterLayer",
            MapMemberIndex = 0
        // Create an image service layer using the colorizer definition created above.
        ImageServiceLayer imageServiceLayerWithColorizer =
      LayerFactory.Instance.CreateLayer<ImageServiceLayer>(rasterLayerCreationParams, map);
    EsriHttpClient: Get a Service Layer and Add it to Pro
      UriBuilder searchURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
        Path = "sharing/rest/search"
      string layers = "(type:\"Map Service\" OR type:\"Image Service\" OR type:\"Feature Service\" OR type:\"WMS\" OR type:\"KML\")";
      //any public layer content
      searchURL.Query = string.Format("q={0}&f=json", layers);
      EsriHttpClient httpClient = new EsriHttpClient();
      var searchResponse = httpClient.Get(searchURL.Uri.ToString());
      dynamic resultItems = JObject.Parse(await searchResponse.Content.ReadAsStringAsync());
      long numberOfTotalItems = resultItems.total.Value;
      if (numberOfTotalItems == 0)
        return;
      List<dynamic> resultItemList = new List<dynamic>();
      resultItemList.AddRange(resultItems.results);
      //get the first result
      dynamic item = resultItemList[0];
      string itemID = item.id;
      Item currentItem = ItemFactory.Instance.Create(itemID, ItemFactory.ItemType.PortalItem);
      await QueuedTask.Run(() =>
        //Create a LayerCreationParam
        var layerParam = new LayerCreationParams(currentItem);
        // if we have an item that can be turned into a layer
        // add it to the map
        if (LayerFactory.Instance.CanCreateLayerFrom(currentItem))
          LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParam, MapView.Active.Map);
    Create GraphicsLayer
      if (map.MapType != MapType.Map)
        return;// not 2D
      var gl_param = new GraphicsLayerCreationParams { Name = "Graphics Layer" };
      // Note: must be called on the QueuedTask
        //By default will be added to the top of the TOC
        graphicsLayer = LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.GraphicsLayer>(gl_param, map);
        //Add to the bottom of the TOC
        gl_param.MapMemberIndex = -1; //bottom
        //Add a graphics layer to a group layer...
        var group_layer = map.GetLayersAsFlattenedList().OfType<GroupLayer>().First();
        LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.GraphicsLayer>(gl_param, group_layer);
        //TODO...use the graphics layer
        // or use the specific CreateGroupLayer method
        LayerFactory.Instance.CreateGroupLayer(map, -1, "Graphics Layer");
    Create a Scene Layer
      // Note: call within QueuedTask.Run()
        //Create with initial visibility set to false. Add to current scene
        var createparams = new LayerCreationParams(new Uri(sceneLayerUrl, UriKind.Absolute))
          IsVisible = false
        //cast to specific type of scene layer being created - in this case FeatureSceneLayer
        var sceneLayer = LayerFactory.Instance.CreateLayer<Layer>(
                 createparams, MapView.Active.Map) as FeatureSceneLayer;
        //or...specify the cast directly
        var sceneLayer2 = LayerFactory.Instance.CreateLayer<FeatureSceneLayer>(
                 createparams, MapView.Active.Map);
        //ditto for BuildingSceneLayer, PointCloudSceneLayer, IntegratedMeshSceneLayer
    Create Voxel Layer
        //Must be a .NetCDF file for voxels
        var url = @"C:\MyData\AirQuality_Redlands.nc";
        var cim_connection = new CIMVoxelDataConnection()
          URI = url
        //Create a VoxelLayerCreationParams
        var createParams = VoxelLayerCreationParams.Create(cim_connection);
        createParams.IsVisible = true;
        //Can also just use the path directly...
        //var createParams = VoxelLayerCreationParams.Create(url);
        //Use VoxelLayerCreationParams to enumerate the variables within
        //the voxel
        var variables = createParams.Variables;
        foreach (var variable in variables)
          var line = $"{variable.Variable}: {variable.DataType}, " +
             $"{variable.Description}, {variable.IsDefault}, {variable.IsSelected}";
          System.Diagnostics.Debug.WriteLine(line);
        //Optional: set the default variable
        createParams.SetDefaultVariable(variables.Last());
        //Create the layer - map must be a local scene
        voxelLayer = LayerFactory.Instance.CreateLayer<VoxelLayer>(createParams, map);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerFactory
    Requirements
