ArcGIS.Desktop.Mapping Namespace / LayerFactory Class
Properties Methods
    LayerFactory Class Members
    The following tables list the members exposed by LayerFactory.
    Public Properties
     NameDescription
    Public Propertystatic (Shared in Visual Basic) Gets the singleton instance for ILayerFactory
    Top
    Public Methods
     NameDescription
    Public Method Gets if the the layer can be copied. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Determines if a new Layer instance using the specified LayerCreationParams can be created and added to the specified container. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Indicates whether a layer can be created from an Item.
    Public MethodIndicates whether Layers can be created using the specified BulkLayerCreationParams and added to the container.
    Public Method Copy a layer. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Create a group layer. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverloaded.
    Top
