public class BulkLayerCreationParams : BulkMapMemberCreationParams
Public Class BulkLayerCreationParams Inherits BulkMapMemberCreationParams
//Uris to the datasets for the layers to be created
var uriShp = new Uri(@"c:\data\roads.shp");
var uriSde = new Uri(@"c:\MyDataConnections\MySDE.sde\Census");
var uri = new Uri(@"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0");
// Create a list of URIs to be used for creating multiple layers
var uris = new List<Uri>() { uriShp, uriSde, uri };
// set the index and visibility
var blkParams = new BulkLayerCreationParams(uris);
blkParams.MapMemberPosition = MapMemberPosition.Index;
blkParams.MapMemberIndex = 2;
blkParams.IsVisible = false;
// blkParams.AutoGroup = true; AutoGroup is set to true by default
// Create multiple layers using the BulkLayerCreationParams
var layers = await QueuedTask.Run(() => LayerFactory.Instance.CreateLayers(blkParams, map));
// same example as "Create multiple layers with BulkLayerCreationParams 1" but without
// adding layers in a group layer
blkParams.AutoGroup = false;
// get a feature class that is selected in the catalog pane
Item item = Project.GetCatalogPane().SelectedItems.FirstOrDefault();
var lcpShp = new FeatureLayerCreationParams(uriShp);
lcpShp.Name = "Roads";
lcpShp.IsVisible = false;
lcpShp.DefinitionQuery = new DefinitionQuery("shpQuery", "OBJECTID > 10");
var lcpItem = new FeatureLayerCreationParams(item);
lcpItem.Name = "Census Polygons";
lcpItem.IsVisible = true;
// list contains a Uri data source and an Item data source
// LayerFactory.Instance.CreateLayers will throw an ArgumentException
var lcps = new List<FeatureLayerCreationParams>();
lcps.Add(lcpShp);
lcps.Add(lcpItem);
var blkParams = new BulkLayerCreationParams(lcps);
// LayerFactory.Instance.CreateLayers will thrown an ArgumentException
// because the LayerCreationParams are created using different
// types of data sources (1 Uri and 1 Item)
var lcpSde = new FeatureLayerCreationParams(uriSde);
lcpSde.Name = "Census Polygons";
lcpSde.IsVisible = true;
var lcpService = new FeatureLayerCreationParams(uri);
lcpService.Name = "Shelters";
lcpService.IsVisible = true;
// set some renderer here ...
//lcpService.RendererDefinition = ...
lcps.Add(lcpShp);
lcps.Add(lcpSde);
lcps.Add(lcpService);
// set the positioning on the BulkLayerCreationParams
blkParams.MapMemberIndex = 0;
// illustrates using a collection of CIMLayerDocument
var layerFile1 = @"c:\data\CitiesRivers.lyrx";
var layerfile2 = @"c:\data\StatesWorld.lyrx";
var layerDoc1 = new LayerDocument(layerFile1);
var cimLayerDoc1 = layerDoc1.GetCIMLayerDocument();
var layerDoc2 = new LayerDocument(layerfile2);
var cimLayerDoc2 = layerDoc2.GetCIMLayerDocument();
var cimLayerDocs = new List<CIMLayerDocument>() { cimLayerDoc1, cimLayerDoc2 };
var blkParams = new BulkLayerCreationParams(cimLayerDocs);
blkParams.AutoGroup = true; // add the layersfiles within an encompassing group layer
lcps.Add(lcpShp);
lcps.Add(lcpSde);
// set the rollback behavior
// - rollback if one or more layers cannot be created due to an invalid data source
blkParams.RollbackBehavior = LayerCreationRollbackBehavior.RollbackOnMissingLayers;
string pathToGeoPackage = @"C:\Data\Geopackage\flooding.gpkg";
//Create lists to hold the URIs of the layers and tables in the geopackage
var layerUris = new List<Uri>();
var tableUris = new List<Uri>();
//Create an item from the geopackage
var item = ItemFactory.Instance.Create(pathToGeoPackage, ItemFactory.ItemType.PathItem);
var children = item.GetItems();
//Collect the table and spatial data in the geopackage
foreach (var child in children)
var childPath = child.Path;
if (child.TypeID == "sqlite_table")
tableUris.Add(new Uri(childPath));
else
layerUris.Add(new Uri(childPath));
//Add the spatial data in the geopackage using the BulkLayerCreationParams
if (layerUris.Count > 0)
BulkLayerCreationParams bulklcp = new BulkLayerCreationParams(layerUris);
LayerFactory.Instance.CreateLayers(bulklcp, map);
// add the tables separately
foreach (var tableUri in tableUris)
StandaloneTableFactory.Instance.CreateStandaloneTable(tableUri, map);
System.Object
ArcGIS.Desktop.Mapping.BaseCreationParams
ArcGIS.Desktop.Mapping.BulkMapMemberCreationParams
ArcGIS.Desktop.Mapping.BulkLayerCreationParams
