ArcGIS.Desktop.Mapping Namespace / LayerFactory Class / CreateLayers Method / CreateLayers(BulkLayerCreationParams,ILayerContainerEdit) Method
A BulkLayerCreationParams object.
A map or group layer where the Layers will be added.
    Creates a readonly list of new Layer instances using the specified BulkLayerCreationParams and adds it to a container such as a map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    layerParams
    container
    Return Value
    A Readonly list of Layer.
    Exceptions
    ExceptionDescription
    layerParams or container is null.
    An elevation surface layer cannot be used as a container for bulk layer creation.
    Unable to bulk create layers with a combination of standard and custom items.
    Unable to bulk create layers with data supplied as a mixture of Uris, Items and data connections.
    Unable to bulk create layers with the supplied child LayerCreationParams.
    Remarks
    The bulk layer creation process creates the layers it is able to per the data supplied. If invalid Uris, data connections or Items exist amongst valid data, then there may be a mismatch in the number of layers created compared to the number of data items supplied. For example, 5 Uris are supplied, but only 4 layers are created because one of the Uris points to a dataset that does not exist. LayerFactory.CreateLayers will return the layers added, but no information regarding the invalid dataset. The only exception to this is if all datasets are invalid (and no layers are created); in this scenario an System.ArgumentException will be thrown.
    See the BulkLayerCreationParams.RollbackBehavior for information about rollback options with bulk layer creation when the BulkLayerCreationParams object is created with a set of LayerCreationParams objects.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
