ArcGIS.Desktop.Mapping Namespace / BulkLayerCreationParams Class
Properties Methods
    BulkLayerCreationParams Class Members
    The following tables list the members exposed by BulkLayerCreationParams.
    Public Constructors
     NameDescription
    Public ConstructorOverloaded.
    Top
    Public Properties
     NameDescription
    Public Property Gets and sets whether the map members being created should be automatically grouped (Inherited from ArcGIS.Desktop.Mapping.BulkMapMemberCreationParams)
    Public Property Gets and sets if the Map is zoomed to the combined extent of the layers if they are the first set of layers to be added to the Map. The default value is true.
    Public PropertyGets the set of ArcGIS.Core.CIM.CIMDataConnection. (Inherited from ArcGIS.Desktop.Mapping.BulkMapMemberCreationParams)
    Public PropertyGets and sets the layer expanded state for all layers. Default value is LayerExpandedState.Default meaning that the expanded state of the layer is set according to the layer type. On creation, some layer types are expanded by default (for example FeatureLayers, CatalogLayers, TopologyLayers); other layer types are collapsed by default (for example TinLayers, TerrainLayers, ParcelLayers).
    Public PropertyGets and sets layer visibility for all layers. The default value is null meaning visibility is set according to the ArcGIS.Desktop.Core.MappingOptions.NewLayersVisible property.
    Public PropertyGets the set of ArcGIS.Desktop.Core.Item. (Inherited from ArcGIS.Desktop.Mapping.BulkMapMemberCreationParams)
    Public PropertyGets the set of ArcGIS.Core.CIM.CIMLayerDocument. (Inherited from ArcGIS.Desktop.Mapping.BulkMapMemberCreationParams)
    Public PropertyGets and sets the index of the first layer in the map or group layer. All subsequent layers added will follow this first layer. MapMemberPosition must be set to MapMemberPosition.Index for this value to honored. If MapMemberPosition is set to MapMemberPosition.Index and this value is NOT set, then the behavior will revert to auto arrange.
    Public PropertyGets and sets the mapMember position. Specifies whether the mapMember should be auto positioned or be on the top or at the bottom. Default value is MapMemberPosition.AutoArrange.
    Public PropertyGets and sets the rollback behavior of the LayerFactory.CreateLayers method. This property only applies if the BulkLayerCreationParams is created with BulkLayerCreationParams Constructor(IEnumerable<LayerCreationParams>), otherwise it is ignored. Default value is LayerCreationRollbackBehavior.NoRollback.
    Public Property Gets and sets custom parameters that are appended to the URL of all requests related to a service layer.
    Public PropertyGets the set of System.Uri that represents the paths or urls to a group of datasets or .lyrx or .lpkx files. (Inherited from ArcGIS.Desktop.Mapping.BulkMapMemberCreationParams)
    Top
    Protected Methods
     NameDescription
    Protected Internal Method Derived classes must call this method to explicitly set the auto-grouping behavior for the map member being created. (Inherited from ArcGIS.Desktop.Mapping.BaseCreationParams)
    Top
