LayerCreationRollbackBehavior Enumeration
Details the set of rollback behaviors for the
LayerFactory.CreateLayers method when the BulkLayerCreationParams object is created with a set of LayerCreationParams objects.
CreateLayers will create the layers it is able to per the data supplied. If invalid data sources are supplied, there will be a mismatch in the number of layers created (and returned from the function) compared to the number of data items supplied. When a set of LayerCreationParams objects exist, the bulk layer creation process applies the appropriate individual layer properties to the created layers, skipping the layer properties for any data sources that are in error. However there may be situations where this logic cannot be correctly applied and so the layers are still created but without the individual properties applied.
Use the BulkLayerCreationParams.RollbackBehavior to control the behavior of bulk layer creation in these scenarios.
Syntax
Members
| Member | Description |
| NoRollback | No rollback of the layer creation process occurs.
The CreateLayers method will create the layers it is able to per the data supplied. Individual layer properties are applied if possible. If not, then the layers created do not have these properties applied. |
| RollbackOnCannotApplyLayerProperties |
The layer creation process is rolled back if there is a mismatch in the number of
layers created compared to the number of data sources supplied AND the correct
individual layer properties cannot be applied.
| RollbackOnMissingLayers |
layers created compared to the number of data sources supplied.
Example
Create multiple layers with BulkLayerCreationParams - Using RollbackBehavior
var uriShp = new Uri(@"c:\data\roads.shp");
var uriSde = new Uri(@"c:\MyDataConnections\MySDE.sde\Census");
var uri = new Uri(@"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0");
var lcpShp = new FeatureLayerCreationParams(uriShp);
lcpShp.Name = "Roads";
lcpShp.IsVisible = false;
lcpShp.DefinitionQuery = new DefinitionQuery("shpQuery", "OBJECTID > 10");
var lcpSde = new FeatureLayerCreationParams(uriSde);
lcpSde.Name = "Census Polygons";
lcpSde.IsVisible = true;
var lcpService = new FeatureLayerCreationParams(uri);
lcpService.Name = "Shelters";
lcpService.IsVisible = true;
// set some renderer here ...
//lcpService.RendererDefinition = ...
var lcps = new List<FeatureLayerCreationParams>();
lcps.Add(lcpShp);
lcps.Add(lcpSde);
lcps.Add(lcpService);
var blkParams = new BulkLayerCreationParams(lcps);
// set the positioning on the BulkLayerCreationParams
blkParams.MapMemberPosition = MapMemberPosition.Index;
blkParams.MapMemberIndex = 0;
// set the rollback behavior
// - rollback if one or more layers cannot be created due to an invalid data source
blkParams.RollbackBehavior = LayerCreationRollbackBehavior.RollbackOnMissingLayers;
var layers = LayerFactory.Instance.CreateLayers(blkParams, MapView.Active.Map);
Inheritance Hierarchy
System.Object
System.ValueType
System.Enum
ArcGIS.Desktop.Mapping.LayerCreationRollbackBehavior
Requirements
ArcGIS Pro version: 3.6 or higher.
