BulkLayerCreationParams Constructor(IEnumerable<LayerCreationParams>)
Creates a parameter object with an enumeration of
LayerCreationParams. The LayerCreationParams objects must be sourced as all Uris or all CIMDataConnections or all Items. Supplying a combination of these will cause
LayerFactory.CreateLayers to throw an ArgumentException.
Syntax
Parameters
- layerCreationParams
- An enumeration of LayerCreationParams objects.
Example
Create multiple layers with BulkLayerCreationParams 2 - invalid
// get a feature class that is selected in the catalog pane
Item item = Project.GetCatalogPane().SelectedItems.FirstOrDefault();
var uriShp = new Uri(@"c:\data\roads.shp");
var lcpShp = new FeatureLayerCreationParams(uriShp);
lcpShp.Name = "Roads";
lcpShp.IsVisible = false;
lcpShp.DefinitionQuery = new DefinitionQuery("shpQuery", "OBJECTID > 10");
var lcpItem = new FeatureLayerCreationParams(item);
lcpItem.Name = "Census Polygons";
lcpItem.IsVisible = true;
// list contains a Uri data source and an Item data source
// LayerFactory.Instance.CreateLayers will throw an ArgumentException
var lcps = new List<FeatureLayerCreationParams>();
lcps.Add(lcpShp);
lcps.Add(lcpItem);
var blkParams = new BulkLayerCreationParams(lcps);
// LayerFactory.Instance.CreateLayers will thrown an ArgumentException
// because the LayerCreationParams are created using different
// types of data sources (1 Uri and 1 Item)
var layers = LayerFactory.Instance.CreateLayers(blkParams, MapView.Active.Map);
Create multiple layers with BulkLayerCreationParams 2 - Valid
var uriSde = new Uri(@"c:\MyDataConnections\MySDE.sde\Census");
var uri = new Uri(@"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0");
var lcpSde = new FeatureLayerCreationParams(uriSde);
lcpSde.Name = "Census Polygons";
lcpSde.IsVisible = true;
var lcpService = new FeatureLayerCreationParams(uri);
lcpService.Name = "Shelters";
lcpService.IsVisible = true;
// set some renderer here ...
//lcpService.RendererDefinition = ...
lcps.Add(lcpShp);
lcps.Add(lcpSde);
lcps.Add(lcpService);
// set the positioning on the BulkLayerCreationParams
blkParams.MapMemberPosition = MapMemberPosition.Index;
blkParams.MapMemberIndex = 0;
Create multiple layers with BulkLayerCreationParams - Using RollbackBehavior
lcps.Add(lcpShp);
lcps.Add(lcpSde);
// set the rollback behavior
// - rollback if one or more layers cannot be created due to an invalid data source
blkParams.RollbackBehavior = LayerCreationRollbackBehavior.RollbackOnMissingLayers;
Requirements
ArcGIS Pro version: 3.6 or higher.
