This property only affects the behavior of the map if it has no non-base map layers. If it is set false it means that the map extent will not change when the layers are added.
If the set of layers to be added are specified by a set of LayerCreationParams objects, then this property overrides the individual LayerCreationParams.AutoZoomOnEmptyMap properties.
