ArcGIS.Desktop.Mapping Namespace / LayerFactory Class / CopyLayer Method
The layer to be copied
A layer container i.e. a map or another group layer where the layer will be copied to.
A 0-based index represents the position of the group layer within the container - 0 means it will added to the very top as the first layer in the container.
    CopyLayer Method (LayerFactory)
    Copy a layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CopyLayer( _
       ByVal layer As Layer, _
       ByVal container As ILayerContainerEdit, _
       Optional ByVal index As Integer _
    ) As Layer
    Parameters
    layer
    container
    index
    Return Value
    Exceptions
    ExceptionDescription
    This layer does not support copying
    Container cannot be null
    Remarks
    Specify the target map or group layer to which the layer will be copied.
    Requirements
