ArcGIS.Desktop.Mapping Namespace / LayerFactory Class / CreateLayer Method
    CreateLayer Method (LayerFactory)
    Overload List
    OverloadDescription
    Creates a new Layer instance using the specified LayerCreationParams and adds that to a container such as a map or group layer. This method must be called on the MCT. Use QueuedTask.Run.
    Creates a new Layer instance with the specified path to a dataset and adds it to a container such as a map or a group layer. Optionally you can provide a name to override the default display name. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
