if (map.MapType != MapType.Map)
return;// not 2D
var gl_param = new GraphicsLayerCreationParams { Name = "Graphics Layer" };
// Note: must be called on the QueuedTask
//By default will be added to the top of the TOC
graphicsLayer = LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.GraphicsLayer>(gl_param, map);
//Add to the bottom of the TOC
gl_param.MapMemberIndex = -1; //bottom
//Add a graphics layer to a group layer...
var group_layer = map.GetLayersAsFlattenedList().OfType<GroupLayer>().First();
LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.GraphicsLayer>(gl_param, group_layer);
//TODO...use the graphics layer
// or use the specific CreateGroupLayer method
LayerFactory.Instance.CreateGroupLayer(map, -1, "Graphics Layer");
