ArcGIS.Desktop.Mapping Namespace / LayerFactory Class / CanCreateLayers Method
A BulkLayerCreationParams object.
A map or group layer where the Layers will be added.
    CanCreateLayers Method (LayerFactory)
    Indicates whether Layers can be created using the specified BulkLayerCreationParams and added to the container.
    Syntax
    Parameters
    layerParams
    container
    Return Value
    A boolean indicates that Layers can be created.
    Remarks
    You should use this method before passing an item to CreateLayers(BulkLayerCreationParams,ILayerContainerEdit)
    Requirements
    ArcGIS Pro version: 3.4 or higher.
