Return Value
An extent.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
var surfaceZResult = await QueuedTask.Run(async () =>
// Get the center of the map's full extent
MapPoint mapPoint = map.CalculateFullExtent().Center;
//Pass any Geometry type to GetZsFromSurfaceAsync
return await map.GetZsFromSurfaceAsync(mapPoint);
if (surfaceZResult.Status == SurfaceZsResultStatus.Ok)
// cast to a mapPoint
var mapPointZ = surfaceZResult.Geometry as MapPoint;
var z = mapPointZ.Z;
await QueuedTask.Run(() =>
TinLayer tinLayer = map.GetLayersAsFlattenedList().OfType<TinLayer>().FirstOrDefault();
MapPoint mapPoint = map.CalculateFullExtent().Center; //Any Map Point
Polyline polyline = PolylineBuilderEx.CreatePolyline(mapView.Extent); //Any Polyline
if (tinLayer.CanGetZs())
// get z value for a mapPoint
var zResult = tinLayer.GetZs(mapPoint);
if (zResult.Status == SurfaceZsResultStatus.Ok)
var mapPointZ = zResult.Geometry as MapPoint;
// get z values for a polyline
zResult = tinLayer.GetZs(polyline);
var polylineZ = zResult.Geometry as Polyline;
