ArcGIS.Desktop.Mapping Namespace / Map Class / FindAndReplaceWorkspacePath Method
A string that represents the workspace path or connection file you want to find. If an empty string is passed, then all workspace paths will be replaced with the replaceWorkspacePath parameter depending on the value of the validate parameter.
A string that represents the workspace path or connection file you want to replace to.
(Optional) -true- the workspace will only be updated if the replaceWorkspacePath value is a valid workspace. If it is not valid, the workspace will not be replaced.
-false- the method will set the workspace to match the replaceWorkspacePath, regardless of a valid match. In this case, if a match does not exist, then layers and standalone tables would appear broken.
(default value = true)
    FindAndReplaceWorkspacePath Method (Map)
    Performs a find and replace of workspace paths for all layers and tables in the map that share that workspace path. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void FindAndReplaceWorkspacePath(
       string findWorkspacePath,
       string replaceWorkspacePath,
       bool validate
    Public Sub FindAndReplaceWorkspacePath( _
       ByVal findWorkspacePath As String, _
       ByVal replaceWorkspacePath As String, _
       Optional ByVal validate As Boolean _
    Parameters
    findWorkspacePath
    validate
    Exceptions
    ExceptionDescription
    Requirements
