ArcGIS.Desktop.Mapping Namespace / Map Class / FindStandaloneTables Method
The name of the StandaloneTable(s)
Example
    FindStandaloneTables Method (Map)
    Finds StandaloneTables by name. Group layers within the map are also searched.
    Syntax
    Public Function FindStandaloneTables( _
       ByVal name As String _
    ) As IReadOnlyList(Of StandaloneTable)
    public IReadOnlyList<StandaloneTable> FindStandaloneTables(
       string name
    Parameters
    name
    Return Value
    A IReadOnlyList of StandaloneTables with the matching name
    Remarks
    A name is not necessarily unique. More than one StandaloneTable can have the same name. To retrieve StandaloneTables from only the map container and not include StandaloneTables within group layers (within the map), use StandaloneTables
    Example
    Find edit template by name on a layer
    // Finds and retrieves specific editing templates by name from layers in the active map.
    await QueuedTask.Run(() =>
      var mainTemplate = activeMap.FindLayers("main").FirstOrDefault()?.GetTemplate("Distribution");
      var mhTemplate = activeMap.FindLayers("Manhole").FirstOrDefault()?.GetTemplate("Active");
    Find table templates belonging to a standalone table
    // retrieve editing templates associated with standalone tables in the active map.
      //Get a particular table template
      var tableTemplate = activeMap.FindStandaloneTables("Address Points").FirstOrDefault()?.GetTemplate("Residences");
      //Get all the templates of a standalone table
      var ownersTableTemplates = activeMap.FindStandaloneTables("Owners").FirstOrDefault()?.GetTemplates();
      var statisticsTableTemplates = activeMap.GetStandaloneTablesAsFlattenedList().First(l => l.Name.Equals("Trading Statistics")).GetTemplates();
    Find a standalone table
        // these routines find a standalone table whether it is a child of the Map or a GroupLayer
        var tblFind = map.FindStandaloneTable("CIMPATH=map/address_audit.xml");
        IReadOnlyList<StandaloneTable> tables = map.FindStandaloneTables("addresses");
        // this method finds a standalone table as a child of the map only
        var table = map.StandaloneTables.FirstOrDefault(t => t.Name == "Addresses");
    Retrieve a table from its container
        var container = MapView.Active.Map;
        //the map standalone table collection
        var table = container.GetStandaloneTablesAsFlattenedList()
                                .FirstOrDefault(tbl => tbl.Name == "EarthquakeDamage");
        //or from a group layer
        var grp_layer = MapView.Active.Map.FindLayers("GroupLayer1").First() as GroupLayer;
        var table2 = grp_layer.FindStandaloneTables("EarthquakeDamage").First();
        //or         grp_layer.GetStandaloneTablesAsFlattenedList().First()
        //or         grp_layer.StandaloneTables.Where(...).First(), etc.
        //show the table in a table view
        //use FrameworkApplication.Current.Dispatcher.BeginInvoke if not on the UI thread
        FrameworkApplication.Panes.OpenTablePane(table2);
    Requirements
