ArcGIS.Desktop.Mapping Namespace / Map Class / GetDefaultExtent Method
Example
    Returns the default full extent of the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Envelope GetDefaultExtent()
    Public Function GetDefaultExtent() As Envelope
    Return Value
    An ArcGIS.Core.Internal.CIM.Envelope representing the default extent
    Exceptions
    ExceptionDescription
    Example
    Calculate Selection tolerance in map units
      //Selection tolerance for the map in pixels
      var selectionTolerance = SelectionEnvironment.SelectionTolerance;
      await QueuedTask.Run(() =>
        //Get the map center
        var mapExtent = mapView.Map.GetDefaultExtent();
        var mapPoint = mapExtent.Center;
        //Map center as screen point
        var screenPoint = mapView.MapToScreen(mapPoint);
        //Add selection tolerance pixels to get a "radius".
        var radiusScreenPoint = new System.Windows.Point(screenPoint.X + selectionTolerance, screenPoint.Y);
        var radiusMapPoint = mapView.ScreenToMap(radiusScreenPoint);
        //Calculate the selection tolerance distance in map units.
        var searchRadius = GeometryEngine.Instance.Distance(mapPoint, radiusMapPoint);
    Requirements
