ArcGIS.Desktop.Mapping Namespace / Map Class / RemoveLayers Method
An enumerable of layers
Example
    RemoveLayers Method (Map)
    Removes the specified layers from the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void RemoveLayers(
       IEnumerable<Layer> layers
    Public Sub RemoveLayers( _
       ByVal layers As IEnumerable(Of Layer) _
    Parameters
    layers
    Exceptions
    ExceptionDescription
    Example
    Removes all layers that are unchecked
      await QueuedTask.Run(() =>
        //Get the group layers first
        IReadOnlyList<GroupLayer> groupLayers = map.Layers.OfType<GroupLayer>().ToList();
        //Iterate and remove the layers within the group layers that are unchecked.
        foreach (var groupLyr in groupLayers)
          //Get layers that not visible within the group
          var layers = groupLyr.Layers.Where(l => l.IsVisible == false).ToList();
          //Remove all the layers that are not visible within the group
          map.RemoveLayers(layers);
        //Group Layers that are empty and are unchecked
        foreach (var group in groupLayers)
          if (group.Layers.Count == 0 && group.IsVisible == false) //No layers in the group
            //remove the group
            map.RemoveLayer(group);
        //Get Layers that are NOT Group layers and are unchecked
        var notAGroupAndUnCheckedLayers = map.Layers.Where(l => !(l is GroupLayer) && l.IsVisible == false).ToList();
        //Remove all the non group layers that are not visible
        map.RemoveLayers(notAGroupAndUnCheckedLayers);
    Remove elevation surface layers
      //Ground will not be removed
      map.ClearElevationSurfaceLayers();
      ElevationSurfaceLayer surfaceLayer = map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "Surface2");
      //Cannot remove ground
      map.RemoveLayer(surfaceLayer);
      map.RemoveLayers(map.GetElevationSurfaceLayers());
    Requirements
