ArcGIS.Desktop.Mapping Namespace / Map Class / RemoveStandaloneTables Method
The StandaloneTables to remove
Example
    RemoveStandaloneTables Method (Map)
    Removes the specified StandaloneTables from the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub RemoveStandaloneTables( _
       ByVal tables As IEnumerable(Of StandaloneTable) _
    public void RemoveStandaloneTables(
       IEnumerable<StandaloneTable> tables
    Parameters
    tables
    Exceptions
    ExceptionDescription
    Remarks
    If the StandaloneTables are in a group layer within the map, they will also be removed.
    Example
    Remove a Standalone table
        //get the first group layer that has at least one table
        var grp_layer = MapView.Active.Map.GetLayersAsFlattenedList()
          .OfType<GroupLayer>().First(g => g.StandaloneTables.Count > 0);
        //Note: Run within a QueuedTask
        //get the tables from the map container
        var tables = map.GetStandaloneTablesAsFlattenedList();
        //delete the first...
        if (tables.Count() > 0)
            map.RemoveStandaloneTable(tables.First());
            //or delete all of them
            map.RemoveStandaloneTables(tables);
        //delete a table from a group layer
        //assumes it has at least one table...
        grp_layer.RemoveStandaloneTable(grp_layer.StandaloneTables.First());
    Requirements
