ArcGIS.Desktop.Mapping Namespace / Map Class / ReplaceDatasource Method
A Datastore that you want to find and be replaced with the replaceDatabaseStore parameter depending on the value of the validate parameter.
A Datastore that you want to replace to.
(Optional) -true- the workspace will only be updated if the replaceDatabaseStore value is a valid workspace. If it is not valid, the workspace will not be replaced.
-false- the method will set the workspace to match the replaceDatabaseStore, regardless of a valid match. In this case, if a match does not exist, then layers and standalone tables would appear broken.
(default value = true)
    ReplaceDatasource Method (Map)
    Performs a find and replace of workspace paths for all layers and tables in the map that share that workspace path. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub ReplaceDatasource( _
       ByVal findDatabaseStore As Datastore, _
       ByVal replaceDatabaseStore As Datastore, _
       Optional ByVal validate As Boolean _
    Parameters
    findDatabaseStore
    validate
    Exceptions
    ExceptionDescription
    Requirements
