ArcGIS.Desktop.Mapping Namespace / Map Class / SetCustomFullExtent Method
An extent or bounding box that will define the full extent of a map.
    Updates the custom full extent of the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetCustomFullExtent(
       Envelope customFullExtent
    Public Sub SetCustomFullExtent( _
       ByVal customFullExtent As Envelope _
    Parameters
    customFullExtent
    Exceptions
    ExceptionDescription
    Requirements
