ArcGIS.Desktop.Mapping Namespace / Map Class / SetReferenceScale Method
A double represents the reference scale of the map.
    Updates the reference scale of the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetReferenceScale(
       double referenceScale
    Public Sub SetReferenceScale( _
       ByVal referenceScale As Double _
    Parameters
    referenceScale
    Exceptions
    ExceptionDescription
    Remarks
    When reference scale is set and a FeatureLayer's ScaleSymbols property is set to true, symbol size will get larger if you zoom in to a scale larger than the ReferenceScale and smaller if you zoom out to a scale smaller than the ReferenceScale.
    Requirements
