public ReadOnlyObservableCollection<Layer> Layers {get;}
Public ReadOnly Property Layers As ReadOnlyObservableCollection(Of Layer)
var featureLayerMapView = MapView.Active;
if (featureLayerMapView == null)
return;
await QueuedTask.Run(() =>
IEnumerable<Layer> layers =
featureLayerMapView.Map.Layers.Where(layer => layer is FeatureLayer);
foreach (FeatureLayer featureLayer in layers)
using (Table table = featureLayer.GetTable())
using (Datastore datastore = table.GetDatastore())
if (datastore is UnknownDatastore)
continue;
Geodatabase geodatabase = datastore as Geodatabase;
//Get the group layers first
IReadOnlyList<GroupLayer> groupLayers = map.Layers.OfType<GroupLayer>().ToList();
//Iterate and remove the layers within the group layers that are unchecked.
foreach (var groupLyr in groupLayers)
//Get layers that not visible within the group
var layers = groupLyr.Layers.Where(l => l.IsVisible == false).ToList();
//Remove all the layers that are not visible within the group
map.RemoveLayers(layers);
//Group Layers that are empty and are unchecked
foreach (var group in groupLayers)
if (group.Layers.Count == 0 && group.IsVisible == false) //No layers in the group
//remove the group
map.RemoveLayer(group);
//Get Layers that are NOT Group layers and are unchecked
var notAGroupAndUnCheckedLayers = map.Layers.Where(l => !(l is GroupLayer) && l.IsVisible == false).ToList();
//Remove all the non group layers that are not visible
map.RemoveLayers(notAGroupAndUnCheckedLayers);
//Zoom to all visible layers in the map.
var visibleLayers = mapView.Map.Layers.Where(l => l.IsVisible);
mapView.ZoomTo(visibleLayers);
//Pan to all visible layers in the map.
mapView.PanTo(visibleLayers);
//Zoom to the selected layers in the TOC
var featureLayers = mapView.Map.Layers.OfType<FeatureLayer>();
mapView.SelectLayers(featureLayers.ToList());
//Get the layer to be masked
var lineLyrToBeMasked = mapView.Map.Layers.FirstOrDefault(lyr => lyr.Name == "TestLine") as FeatureLayer;
//Get the layer's definition
var lyrDefn = lineLyrToBeMasked.GetDefinition();
//Create an array of Masking layers (polygon only)
//Set the LayerMasks property of the Masked layer
lyrDefn.LayerMasks = ["CIMPATH=map3/testpoly.xml"];
//Re-set the Masked layer's definition
lineLyrToBeMasked.SetDefinition(lyrDefn);
