public SpatialReference SpatialReference {get;}
Public ReadOnly Property SpatialReference As SpatialReference
//Get the current view camera location
var center_pt = new Coordinate2D(mapView.Camera.X, mapView.Camera.Y);
//Get the current location unit
var loc_unit = await QueuedTask.Run(() => map.GetLocationUnitFormat());
//Format the camera location
var str = loc_unit.FormatLocation(center_pt, map.SpatialReference);
System.Diagnostics.Debug.WriteLine($"Formatted location: {str}");
//Create a point
var pt = MapPointBuilderEx.CreateMapPoint(x, y, spatialReference);
//Buffer it - for purpose of zoom
var poly = GeometryEngine.Instance.Buffer(pt, buffer_size);
//do we need to project the buffer polygon?
if (!mapView.Map.SpatialReference.IsEqual(poly.SpatialReference))
//project the polygon
poly = GeometryEngine.Instance.Project(poly, mapView.Map.SpatialReference);
//Zoom - add in a delay for animation effect
mapView.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
tinLayer = null;
MapPoint observerPoint = null;
MapPoint targetPoint = null;
CIMPointSymbol obstructionPointSymbol = null;
CIMLineSymbol visibleLineSymbol = null;
CIMLineSymbol invisibleLineSymbol = null;
var losParams = new LineOfSightParams();
losParams.ObserverPoint = observerPoint;
losParams.TargetPoint = targetPoint;
// add offsets if appropriate
// losParams.ObserverHeightOffset = observerOffset;
// losParams.TargetHeightOffset = targerOffset;
// add obstruction feature class if appropriate (multipatch)
//losParams.ObstructionsMultipatchFeatureClass = obsFeatureClass;
// set output spatial reference
losParams.OutputSpatialReference = mapView.Map.SpatialReference;
LineOfSightResult results = null;
try
if (tinLayer.CanGetLineOfSight(losParams))
results = tinLayer.GetLineOfSight(losParams);
catch (Exception)
// handle exception
if (results != null)
bool targetIsVisibleFromObserverPoint = results.IsTargetVisibleFromObserverPoint;
//These properties are not used. They will always be false
// results.IsTargetVisibleFromVisibleLine;
// results.IsTargetVisibleFromInvisibleLine;
if (results.VisibleLine != null)
mapView.AddOverlay(results.VisibleLine, visibleLineSymbol.MakeSymbolReference());
if (results.InvisibleLine != null)
mapView.AddOverlay(results.VisibleLine, invisibleLineSymbol.MakeSymbolReference());
if (results.ObstructionPoint != null)
mapView.AddOverlay(results.ObstructionPoint, obstructionPointSymbol.MakeSymbolReference());
var mapView = MapView.Active;
if (mapView == null)
return;
if (!featSceneLayer.HasAssociatedFeatureService)
return;//no search or select
//Select all features within the current map view
var sz = mapView.GetViewSize();
var map_pt1 = mapView.ClientToMap(new System.Windows.Point(0, sz.Height));
var map_pt2 = mapView.ClientToMap(new System.Windows.Point(sz.Width, 0));
//Convert to an envelope
var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, mapView.Map.SpatialReference);
//Project if needed to the layer spatial ref
SpatialReference sr = null;
using (var fc = featSceneLayer.GetFeatureClass())
using (var fdef = fc.GetDefinition())
sr = fdef.GetSpatialReference();
var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
//Set up a query filter
var sf = new SpatialQueryFilter()
FilterGeometry = env,
SpatialRelationship = SpatialRelationship.Intersects,
SubFields = "*"
//Select against the feature service
var select = featSceneLayer.Select(sf);
if (select.GetCount() > 0)
//enumerate over the selected features
using (var rc = select.Search())
while (rc.MoveNext())
using (var feature = rc.Current as Feature)
oid = feature.GetObjectID();
//etc.
mapView.Map.ClearSelection();
