Public Overloads Function PanToAsync( _ ByVal layers As IEnumerable(Of Layer), _ Optional ByVal selectedOnly As Boolean, _ Optional ByVal duration As Nullable(Of TimeSpan) _ ) As Task(Of Boolean)
public Task<bool> PanToAsync( IEnumerable<Layer> layers, bool selectedOnly, Nullable<TimeSpan> duration )
Parameters
- layers
- An enumeration of layers containing the features in which to pan.
- selectedOnly
- Indicates whether only the selected features for a layer should be used to determine the extent in which to pan.
- duration
- The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Return Value
True if the navigation is completed, false if it was interrupted by another view navigation.
