ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomTo Method / ZoomTo(Geometry,Nullable<TimeSpan>,Boolean) Method
The geometry defining the extent in which to zoom.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Indicates if the Pitch and Heading should remain the same after the navigation is completed. If false the Heading will be set to 15.0 and the Pitch will be set to -60.0. This parameter only effects 3D views.
Example
    Zoom the view to the extent defined by a geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function ZoomTo( _
       ByVal geometry As Geometry, _
       Optional ByVal duration As Nullable(Of TimeSpan), _
       Optional ByVal maintainViewDirection As Boolean _
    ) As Boolean
    Parameters
    geometry
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    Remarks
    This is equivalent to setting the extent of the view. Use this method in combination with the Extent property to get and then modify the view's extent. If the geometry's spatial reference is in a different spatial reference than the map this method projects the geometry into the spatial reference of the map.
    Example
    Zoom to a specified point
      double x = -122.45;
      double y = 37.75;
      double buffer_size = 0.1;
      //Create a point
      var pt = MapPointBuilderEx.CreateMapPoint(x, y,
                     SpatialReferenceBuilder.CreateSpatialReference(4326));
      //Buffer it - for purpose of zoom
      var poly = GeometryEngine.Instance.Buffer(pt, buffer_size);
      //do we need to project the buffer polygon?
      if (!MapView.Active.Map.SpatialReference.IsEqual(poly.SpatialReference))
        //project the polygon
        poly = GeometryEngine.Instance.Project(poly, MapView.Active.Map.SpatialReference);
      // Must run on MCT.
      QueuedTask.Run(() =>
        //Zoom - add in a delay for animation effect
        MapView.Active.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
    Zoom To a Point
      // Note: Needs QueuedTask to run
        //Create a point
        var pt = MapPointBuilderEx.CreateMapPoint(x, y, spatialReference);
        mapView.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
    Rotate the map view
      //Get the camera for the view, adjust the heading and zoom to the new camera position.
      camera = mapView.Camera;
      camera.Heading = heading;
      await mapView.ZoomToAsync(camera, TimeSpan.Zero);
      //Or synchronously
      mapView.ZoomTo(camera, TimeSpan.Zero);
    Expand Extent
      //Note: Needs QueuedTask to run
        //Expand the current extent by the given ratio.
        var extent = mapView.Extent;
        var newExtent = GeometryEngine.Instance.Expand(extent, dx, dy, true);
        mapView.ZoomTo(newExtent);
    Requirements
