ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomTo Method / ZoomTo(BasicFeatureLayer,Int64,Nullable<TimeSpan>,Boolean) Method
The layer containing the feature in which to zoom.
The Object ID of the feature in the layer in which to zoom.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Indicates if the Pitch and Heading should remain the same after the navigation is completed. If false the Heading will be set to 15.0 and the Pitch will be set to -60.0. This parameter only effects 3D views.
    Zoom the view to the extent of a feature. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function ZoomTo( _
       ByVal layer As BasicFeatureLayer, _
       ByVal objectID As Long, _
       Optional ByVal duration As Nullable(Of TimeSpan), _
       Optional ByVal maintainViewDirection As Boolean _
    ) As Boolean
    Parameters
    layer
    objectID
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    The map viewer is not initialized.
    The layer is null.
    Requirements
