ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomToAsync Method / ZoomToAsync(Geometry,Nullable<TimeSpan>,Boolean) Method
The geometry defining the extent in which to zoom.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Indicates if the Pitch and Heading should remain the same after the navigation is completed. If false the Heading will be set to 15.0 and the Pitch will be set to -60.0. This parameter only effects 3D views.
Example
    Zoom the view to the extent defined by a geometry.
    Syntax
    Public Overloads Function ZoomToAsync( _
       ByVal geometry As Geometry, _
       Optional ByVal duration As Nullable(Of TimeSpan), _
       Optional ByVal maintainViewDirection As Boolean _
    ) As Task(Of Boolean)
    Parameters
    geometry
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Remarks
    This is equivalent to setting the extent of the view. Use this method in combination with the Extent property to get and then modify the view's extent. If the geometry's spatial reference is in a different spatial reference than the map this method projects the geometry into the spatial reference of the map.
    Example
    Zoom To an Extent
      envelope = EnvelopeBuilderEx.CreateEnvelope(xMin, yMin, xMax, yMax, spatialReference);
      //Zoom the view to a given extent.
      mapView.ZoomToAsync(envelope, TimeSpan.FromSeconds(2));
    Requirements
