ArcGIS.Desktop.Mapping Namespace / PDFFormat Class / PDFFormat Constructor
Example
    Initialize a new instance of PDFFormat.
    Syntax
    Public Function New()
    public PDFFormat()
    Example
    Export a layout to PDF
      //Export a single page layout to PDF.
      //Create a PDF format with appropriate settings
      //BMP, EMF, EPS, GIF, JPEG, PNG, SVG, TGA, and TFF formats are also available for export
      string filePath = @"Path and file name for the output export file";
      PDFFormat PDF = new PDFFormat()
        OutputFileName = filePath,
        Resolution = 300,
        DoCompressVectorGraphics = true,
        DoEmbedFonts = true,
        HasGeoRefInfo = true,
        ImageCompression = ImageCompression.Adaptive,
        ImageQuality = ImageQuality.Best,
        LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
      //Check to see if the path is valid and export
      if (PDF.ValidateOutputFilePath())
        //Note: Must be on QueuedTask.Run
        layout.Export(PDF);  //Export the layout to PDF on the worker thread
    Export a map series to single PDF
      //Export a map series with multiple pages to a single PDF.
      //Create PDF format with appropriate settings
      PDFFormat MS_PDF = new PDFFormat()
        Resolution = 300,
      //Set up map series export options
      MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
        ExportPages = ExportPages.Custom,  //Provide a specific list of pages
        CustomPages = "1-3, 5",  //Only used if ExportPages.Custom is set
        ExportFileOptions = ExportFileOptions.ExportAsSinglePDF,  //Export all pages to a single, multi-page PDF
        ShowSelectedSymbology = false  //Do no show selection symbology in the output
      //Export on the worker thread
      if (MS_PDF.ValidateOutputFilePath())
        layout.Export(MS_PDF, MS_ExportOptions);  //Export to PDF
    Requirements
