Use this option if you want to create the content for the pop-up dynamically when the item is displayed in the window. This is useful if you are going to be showing multiple items in the pop-up window and don't want to generate the content for the item until it is viewed in the window. To take advantage of this dynamic content creation you must derive from the PopupContent class and override the OnCreateHtmlContent method. This method will be called the first time the content for the item is requested.
Requirements
