ArcGIS.Desktop.Mapping Namespace / ProportionalRendererDefinition Class
Members Example
    Represents a proportional renderer definition to draw features proportionally to each other.
    Object Model
    ProportionalRendererDefinition ClassCIMPolygonSymbol ClassCIMSymbolReference ClassCIMSymbolReference ClassCIMSymbolReference ClassCIMSymbolReference Class
    Syntax
    public class ProportionalRendererDefinition : RendererDefinition
    Public Class ProportionalRendererDefinition
       Inherits RendererDefinition
    Remarks
    Once you define a proportional renderer, you can call a FeatureLayer's CreateRenderer and SetRenderer methods to create and assign a renderer to a feature layer.
    Example
    Create a Proportion Renderer with max and min symbol size capped
      string colorBrewerSchemesName = "ArcGIS Colors";
      //Get the style project item that contains the color ramps
      //Refer to the Initialize region for an example of how to get a style item
      await QueuedTask.Run(() =>
      //Creating a point symbol to be used as a template symbol for the proportional renderer
      CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
      CIMSymbolReference symbolPointTemplate = pointSym.MakeSymbolReference();
      //minimum symbol size is capped to 4 point while the maximum symbol size is set to 50 point
      //Creating a proportional renderer definition that uses the "Population" field
      ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", symbolPointTemplate, 4, 50, true)
        //setting upper and lower size stops to stop symbols growing or shrinking beyond those thresholds
        UpperSizeStop = 5000000,  //features with values >= 5,000,000 will be drawn with maximum symbol size
        LowerSizeStop = 50000    //features with values <= 50,000 will be drawn with minimum symbol size
      // Create a proportional renderer using the definition
      CIMProportionalRenderer propRndr = featureLayer.CreateRenderer(prDef) as CIMProportionalRenderer;
      // Set the renderer to the feature layer
      featureLayer.SetRenderer(propRndr);
    Create a True Proportion Renderer
      //Defining proportional renderer where size of symbol will be same as its value in field used in the renderer.
      ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", esriUnits.esriMeters, symbolPointTemplate, SymbolShapes.Square, ValueRepresentations.Radius);
      //Create a Proportional renderer using the definition
    Proportional symbols renderer.
    /// <summary>
    /// Renders a feature layer using proportional symbols to draw quantities.
    /// ![Proportional Symbols renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/proportional-renderer.png)
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      //Gets the first numeric field of the feature layer
      var firstNumericFieldOfFeatureLayer = "NumericFieldInLayer";
      //Gets the min and max value of the field
      var sizes = await GetFieldMinMaxAsync(featureLayer, firstNumericFieldOfFeatureLayer);
      ProportionalRendererDefinition prDef = new ProportionalRendererDefinition()
        Field = firstNumericFieldOfFeatureLayer,
        MinimumSymbolSize = 4,
        MaximumSymbolSize = 50,
        LowerSizeStop = Convert.ToDouble(sizes.Item1),
        UpperSizeStop = Convert.ToDouble(sizes.Item2)
        CIMProportionalRenderer propRndr = (CIMProportionalRenderer)featureLayer.CreateRenderer(prDef);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.RendererDefinition
             ArcGIS.Desktop.Mapping.ProportionalRendererDefinition
    Requirements
