ArcGIS.Desktop.Mapping Namespace / ProportionalRendererDefinition Class / MinimumSymbolSize Property
Example
    MinimumSymbolSize Property (ProportionalRendererDefinition)
    Gets or sets the minimum symbol size used in the renderer.
    Syntax
    public double MinimumSymbolSize {get; set;}
    Public Property MinimumSymbolSize As Double
    Remarks
    The default value is 4.0.
    Example
    Proportional symbols renderer.
    /// <summary>
    /// Renders a feature layer using proportional symbols to draw quantities.
    /// ![Proportional Symbols renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/proportional-renderer.png)
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      //Gets the first numeric field of the feature layer
      var firstNumericFieldOfFeatureLayer = "NumericFieldInLayer";
      //Gets the min and max value of the field
      var sizes = await GetFieldMinMaxAsync(featureLayer, firstNumericFieldOfFeatureLayer);
      ProportionalRendererDefinition prDef = new ProportionalRendererDefinition()
        Field = firstNumericFieldOfFeatureLayer,
        MinimumSymbolSize = 4,
        MaximumSymbolSize = 50,
        LowerSizeStop = Convert.ToDouble(sizes.Item1),
        UpperSizeStop = Convert.ToDouble(sizes.Item2)
      await QueuedTask.Run(() =>
        CIMProportionalRenderer propRndr = (CIMProportionalRenderer)featureLayer.CreateRenderer(prDef);
        featureLayer.SetRenderer(propRndr);
    Requirements
