Public Class ScaleBarStyleItem Inherits StyleItem Implements System.ComponentModel.INotifyPropertyChanged
public class ScaleBarStyleItem : StyleItem, System.ComponentModel.INotifyPropertyChanged
//Create a scale bar using a style.
//Search for a style project item by name
StyleProjectItem arcgis_2dStyle = Project.Current.GetItems<StyleProjectItem>()
.First(si => si.Name == "ArcGIS 2D");
//Note: Must be on QueuedTask.Run
//Reference the specific scale bar by name
ScaleBarStyleItem scaleBarItem = arcgis_2dStyle.SearchScaleBars(
"Double Alternating Scale Bar").FirstOrDefault();
//Reference the map frame and define the location
MapFrame myMapFrame = layout.FindElement("Map Frame") as MapFrame;
Coordinate2D coord2D = new Coordinate2D(10.0, 7.0);
//Construct the scale bar
var sbarInfo = new ScaleBarInfo()
MapFrameName = myMapFrame.Name,
ScaleBarStyleItem = scaleBarItem
ElementFactory.Instance.CreateMapSurroundElement(
layout, coord2D.ToMapPoint(), sbarInfo);
//Build geometry
Coordinate2D ll = new Coordinate2D(5.0, 6);
Coordinate2D ur = new Coordinate2D(6.0, 7);
Envelope sbEnv = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
//Reference a Scale Bar in a style
StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
.FirstOrDefault(item => item.Name == "ArcGIS 2D");
ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
"Alternating Scale Bar 1")[0];
//ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
// "Double Alternating Scale Bar 1")[0];
// "Hollow Scale Bar 1")[0];
//Create Scale Bar
ScaleBarInfo sbInfo = new ScaleBarInfo()
MapFrameName = mapFrame.Name,
var sbElm = ElementFactory.Instance.CreateMapSurroundElement(
layout, sbEnv, sbInfo) as ScaleBar;
//Build geometry
Coordinate2D ll = new Coordinate2D(5.0, 8);
Coordinate2D ur = new Coordinate2D(6.0, 9);
"Scale Line 1")[0];
// "Stepped Scale Line")[0];
// "Scale Line 2")[0];
//Create Scale Bar
ScaleBarStyleItem = sbStyleItm
layout, sbEnv, sbInfo, "ScaleBar Line") as ScaleBar;
//Search for scale bars
//Note: styleProjectItem was created above in the variable initialization section
//Note: Needs QueuedTask to run
styleProjectItem.SearchScaleBars("searchString");
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Mapping.StyleItem
ArcGIS.Desktop.Mapping.ScaleBarStyleItem
