ArcGIS.Desktop.Mapping Namespace / Snapping Class / SetSnapMode Method
Example
    SetSnapMode Method (Snapping)
    Sets the state of a single SnapMode.
    Syntax
    Public Shared Sub SetSnapMode( _
       ByVal mode As SnapMode, _
       ByVal value As Boolean _
    public static void SetSnapMode(
       SnapMode mode,
       bool value
    Parameters
    mode
    value
    Example
    Configure Snapping - Application SnapModes
    // set only Point and Edge snapping modes, clear everything else
    Snapping.SetSnapModes(
      new List<SnapMode>() { SnapMode.Point, SnapMode.Edge });
    // clear all snap modes
    Snapping.SetSnapModes(null);
    // set snap modes one at a time
    Snapping.SetSnapMode(SnapMode.Edge, true);
    Snapping.SetSnapMode(SnapMode.End, true);
    Snapping.SetSnapMode(SnapMode.Intersection, true);
    // get current snap modes
    var snapModes = Snapping.SnapModes;
    // get state of a specific snap mode
    bool isOn = Snapping.GetSnapMode(SnapMode.Vertex);
    Configure Snapping - Combined Example
    // interested in only snapping to the vertices of a specific layer of interest and not the vertices of other layers
    //  all other snapModes should be off.
    // snapping must be on
    Snapping.IsEnabled = true;
    // turn all application snapModes off
    // set application snapMode vertex on
    Snapping.SetSnapMode(SnapMode.Vertex, true);
    // ensure layer snapping is on
    await QueuedTask.Run(() =>
      featureLayer.SetSnappable(true);
    // set vertex snapping only
    var vertexOnly = new LayerSnapModes(false) { Vertex = true };
    // set vertex only for the specific layer, clearing all others
    var dict = new Dictionary<Layer, LayerSnapModes>();
    dict.Add(featureLayer, vertexOnly);
    Snapping.SetLayerSnapModes(dict, true);  // true = reset other layers
    Requirements
