ArcGIS.Desktop.Mapping Namespace / SnappingOptions Class / ZTolerance Property
Example
    ZTolerance Property (SnappingOptions)
    Gets or sets the ZTolerance.
    Syntax
    Public Property ZTolerance As Double
    public double ZTolerance {get; set;}
    Example
    Snap Options
    var myMap = MapView.Active.Map;
    // Set snapping options via get/set options
    var snapOptions = Snapping.GetOptions(myMap);
    snapOptions.IsSnapToSketchEnabled = true;
    snapOptions.XYTolerance = 100;
    snapOptions.IsZToleranceEnabled = true;
    snapOptions.ZTolerance = 0.6;
    // turn on snap tip display parts
    snapOptions.SnapTipDisplayParts = (int)SnapTipDisplayPart.SnapTipDisplayLayer + (int)SnapTipDisplayPart.SnapTipDisplayType;
    // turn off all snaptips
    // snapOptions.SnapTipDisplayParts = (int)SnapTipDisplayPart.SnapTipDisplayNone;
    // turn on layer display only
    // snapOptions.SnapTipDisplayParts = (int)SnapTipDisplayPart.SnapTipDisplayLayer;
    snapOptions.SnapTipColor = ColorFactory.Instance.RedRGB;
    Snapping.SetOptions(myMap, snapOptions);
    Requirements
