/// <summary>
/// Creates a point symbol with custom fill and outline
/// </summary>
//Note: Run withing QueuedTask
var circlePtCustomFileOutlineSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB, 6, SimpleMarkerStyle.Circle);
//Modifying this point symbol with the attributes we want.
//getting the marker that is used to render the symbol
var marker = circlePtCustomFileOutlineSymbol.SymbolLayers[0] as CIMVectorMarker;
//Getting the polygon symbol layers components in the marker
var polySymbol = marker.MarkerGraphics[0].Symbol as CIMPolygonSymbol;
//modifying the polygon's outline and width per requirements
polySymbol.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 2, SimpleLineStyle.Solid); //This is the outline
polySymbol.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.GreenRGB); //This is the fill
//To apply the symbol to a point feature layer
//var renderer = pointLayer.GetRenderer() as CIMSimpleRenderer;
//renderer.Symbol = circlePtCustomFileOutlineSymbol.MakeSymbolReference();
//pointLayer.SetRenderer(renderer);
