//Create a simple 2D rectangle graphic and apply simple fill and
//outline symbols.
//Note: Must be on QueuedTask.Run
//Build 2D envelope geometry
Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
//Set symbology, create and add element to layout
CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
layout, rec_env, polySym, "New Rectangle");
//Or use Predefined shape
GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
layout, PredefinedShape.Rectangle, rec_env, polySym,
"New Rectangle2");
