ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / ConstructStroke Method / ConstructStroke(CIMColor,Double) Method
ArcGIS.Core.CIM.CIMColor
The width of stroke to construct.
Example
    Constructs a stroke of specific color and width.
    Syntax
    Public Overloads Function ConstructStroke( _
       ByVal color As CIMColor, _
       ByVal width As Double _
    ) As CIMStroke
    public CIMStroke ConstructStroke(
       CIMColor color,
       double width
    Parameters
    color
    width
    Return Value
    Example
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      //Note: Must be on QueuedTask.Run
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    How to construct a line symbol from a stroke
        CIMStroke stroke = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 2.0);
        CIMLineSymbol lineSymbolFromStroke = SymbolFactory.Instance.ConstructLineSymbol(stroke);
    How to construct a multilayer line symbol with circle markers on the line ends
        //Note: Needs QueuedTask to run
        var lineStrokeRed = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 4.0);
        var markerCircle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Circle);
        markerCircle.MarkerPlacement = new CIMMarkerPlacementOnVertices()
            AngleToLine = true,
            PlaceOnEndPoints = true,
            Offset = 0
        var lineSymbolWithCircles = new CIMLineSymbol()
            SymbolLayers = new CIMSymbolLayer[2] { markerCircle, lineStrokeRed }
    Requirements
