If set to true and a valid GeoReferenceMapFrameName is set, a world file will be generated based on the map frame's coordinate system.
If you export a 3D view, this parameter will be ignored regardless of the setting because world files are not applicable to 3D views.
The default value is false.
//Export each page of a map series to an individual TIFF file.
string filePath = @"Path and file name for the output export file";
//Create TIFF format with appropriate settings
TIFFFormat TIFF = new TIFFFormat()
OutputFileName = filePath,
Resolution = 300,
ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
HasGeoTiffTags = true,
HasWorldFile = true,
ImageCompression = TIFFImageCompression.LZW
//Set up map series export options
MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
ExportPages = ExportPages.All, //All pages
ExportFileOptions = ExportFileOptions.ExportMultipleNames, //Export each page to an individual file using page name as a suffix.
ShowSelectedSymbology = true //Include selection symbology in the output
//Export on the worker thread
//Check to see if the path is valid and export
if (TIFF.ValidateOutputFilePath())
await QueuedTask.Run(() => layout.Export(TIFF, MSExportOptions_TIFF)); //Export to TIFF
