ArcGIS.Desktop.Mapping Namespace / TIFFFormat Class
Properties Methods
    TIFFFormat Class Members
    The following tables list the members exposed by TIFFFormat.
    Public Constructors
     NameDescription
    Public Constructor Initialize a new instance of TIFFFormat.
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the number of bits used to describe color.
    Public Property Get or sets if the layout is clipped to the smallest bounding box that encompasses all layout elements. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Get or sets if the selection symbology should be shown for all the layers. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets the name of the map frame used to define the coordinate system for georeference information.
    Public Property Gets or sets if a color profile is embedded.
    Public Property Gets or sets if geoTIFF tags are included. If set to true and a valid GeoReferenceMapFrameName is set, geoTIFF tags will be embedded in the resulting image based on the map frame's coordinate system.
    Public Property Gets or sets if the background will be transparent.
    Public Property Gets or sets if a georeferenced world file will be created.
    Public Property Gets or sets the caption. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets the number of pixels that represents the height of the output file. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets the compression scheme.
    Public Property This value (0–100) controls the amount of compression applied to the output image. With a JPEG image, quality is adversely affected the more compression is applied. A higher quality (highest = 100) setting will produce sharper images and larger file sizes. A lower quality setting will produce more image artifacts and smaller files.
    Public Property Gets or sets the path and file name for the output export file. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets the resolution of the export file in dots per inch (DPI). (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Public Property Gets or sets the threshold value to indicate black and white color for the image intensities.
    Public Property Gets or sets the number of pixels that represents the width of the output file. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Top
    Public Methods
     NameDescription
    Public Method Validates the output file path. (Inherited from ArcGIS.Desktop.Mapping.ExportFormat)
    Top
