ArcGIS.Desktop.Mapping Namespace / TIFFFormat Class / ColorMode Property
Example
    ColorMode Property (TIFFFormat)
    Gets or sets the number of bits used to describe color.
    Syntax
    public TIFFColorMode ColorMode {get; set;}
    Public Property ColorMode As TIFFColorMode
    Remarks
    The values available are defined in TIFFColorMode.
    (The default value is TIFFColorMode.TwentyFourBitTrueColor.
    Example
    Export a map series to individual TIFF files
      //Export each page of a map series to an individual TIFF file.
      string filePath = @"Path and file name for the output export file";
      //Create TIFF format with appropriate settings
      TIFFFormat TIFF = new TIFFFormat()
        OutputFileName = filePath,
        Resolution = 300,
        ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
        HasGeoTiffTags = true,
        HasWorldFile = true,
        ImageCompression = TIFFImageCompression.LZW
      //Set up map series export options
      MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
        ExportPages = ExportPages.All,  //All pages
        ExportFileOptions = ExportFileOptions.ExportMultipleNames,  //Export each page to an individual file using page name as a suffix.
        ShowSelectedSymbology = true  //Include selection symbology in the output
      //Export on the worker thread
      //Check to see if the path is valid and export
      if (TIFF.ValidateOutputFilePath())
        await QueuedTask.Run(() => layout.Export(TIFF, MSExportOptions_TIFF));  //Export to TIFF
    Requirements
