ImageCompressionQuality Property (TIFFFormat)
This value (0–100) controls the amount of compression applied to the output image. With a JPEG image, quality is
adversely affected the more compression is applied. A higher quality (highest = 100) setting will produce sharper
images and larger file sizes. A lower quality setting will produce more image artifacts and smaller files.
