ArcGIS.Desktop.Mapping Namespace / TimeRange Class / Offset Method
The time interval to offset the current instance by.
Example
    Offset Method (TimeRange)
    Returns a new time range offset from the current instance using the specified time interval.
    Syntax
    Public Function Offset( _
       ByVal timeDelta As TimeDelta _
    ) As TimeRange
    public TimeRange Offset(
       TimeDelta timeDelta
    Parameters
    timeDelta
    Return Value
    A new TimeRange that is equal to this instance offset by the time interval represented by timeDelta.
    Example
    Step forward in time by 1 month
      //Step current map time forward by 1 month
      TimeDelta timeDelta = new(1, TimeUnit.Months);
      mapView.Time = mapView.Time.Offset(timeDelta);
    Requirements
