ArcGIS.Desktop.Mapping Namespace / UnclassedColorsRendererDefinition Class
Members Example
    Represents an unclassed colors renderer definition to show qualitative differences in feature values with an evenly distributed color scheme.
    Object Model
    UnclassedColorsRendererDefinition ClassCIMColorRamp ClassCIMSymbolReference ClassCIMSymbolReference Class
    Syntax
    Public Class UnclassedColorsRendererDefinition
       Inherits RendererDefinition
    public class UnclassedColorsRendererDefinition : RendererDefinition
    Remarks
    Unclassed colors symbology is similar to graduated colors in that it's used to make choropleth maps.
    Once you define an unclassed renderer, you can call a FeatureLayer's CreateRenderer and SetRenderer methods to create and assign a renderer to a feature layer.
    Example
    Create an unclassed Renderer
        string colorBrewerSchemesName = "ArcGIS Colors";
        //Get the style project item that contains the color ramps
        //Refer to the Initialize region for an example of how to get a style item
        //Note: Run within a QueuedTask
        CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Diamond);
        CIMSymbolReference symbolPointTemplate = pointSym.MakeSymbolReference();
        //defining an unclassed renderer with custom upper and lower stops
        //all features with value >= 5,000,000 will be drawn with the upper color from the color ramp
        //all features with value <= 50,000 will be drawn with the lower color from the color ramp
        UnclassedColorsRendererDefinition unclassRndrDef = new UnclassedColorsRendererDefinition
                              ("Population", symbolPointTemplate, colorRamp, "Highest", "Lowest", 5000000, 50000)
            //drawing features with null values with a different symbol
            ShowNullValues = true,
            NullValueLabel = "Unknown"
        // Create a point symbol for null values
        CIMPointSymbol nullSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 16.0, SimpleMarkerStyle.Circle);
        unclassRndrDef.NullValueSymbol = nullSym.MakeSymbolReference();
        //Create the unclassed renderer using the definition
        CIMClassBreaksRenderer cbRndr = featureLayer.CreateRenderer(unclassRndrDef) as CIMClassBreaksRenderer;
        //Set the renderer to the feature layer
        featureLayer.SetRenderer(cbRndr);
    UnClassed graduated color renderer.
    /// <summary>
    /// Renders a feature layer using an unclassed color gradient.
    /// ![cb-unclassed.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/cb-unclassed.png "Class breaks unclassed renderer.")
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "U.S. National Transportation Atlas Interstate Highways");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the U.S. National Transportation Atlas Interstate Highways feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      //Gets the first numeric field of the feature layer
      var firstNumericFieldOfFeatureLayer = "NumericFieldInFeatureLayer";
      //Gets the min and max value of the field
      //Refer to the GetFieldMinMax function below
      var labels = GetFieldMinMax(featureLayer, firstNumericFieldOfFeatureLayer);
      UnclassedColorsRendererDefinition ucDef = new UnclassedColorsRendererDefinition()
        Field = firstNumericFieldOfFeatureLayer,
        ColorRamp = colorRamp,
        LowerColorStop = Convert.ToDouble(labels.Item1),
        UpperColorStop = Convert.ToDouble(labels.Item2),
        UpperLabel = labels.Item2,
        LowerLabel = labels.Item1,
      //Note: Run within QueuedTask
      CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(ucDef);
      featureLayer?.SetRenderer(renderer);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.RendererDefinition
             ArcGIS.Desktop.Mapping.UnclassedColorsRendererDefinition
    Requirements
