ArcGIS.Desktop.Mapping Namespace / UnclassedColorsRendererDefinition Class / Field Property
Example
    Field Property (UnclassedColorsRendererDefinition)
    Gets or sets the field to be used in the renderer.
    Syntax
    public string Field {get; set;}
    Public Property Field As String
    Example
    UnClassed graduated color renderer.
    /// <summary>
    /// Renders a feature layer using an unclassed color gradient.
    /// ![cb-unclassed.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/cb-unclassed.png "Class breaks unclassed renderer.")
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "U.S. National Transportation Atlas Interstate Highways");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the U.S. National Transportation Atlas Interstate Highways feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      //Gets the first numeric field of the feature layer
      var firstNumericFieldOfFeatureLayer = "NumericFieldInFeatureLayer";
      //Gets the min and max value of the field
      //Refer to the GetFieldMinMax function below
      var labels = await GetFieldMinMaxAsync(featureLayer, firstNumericFieldOfFeatureLayer);
      UnclassedColorsRendererDefinition ucDef = new UnclassedColorsRendererDefinition()
        Field = firstNumericFieldOfFeatureLayer,
        ColorRamp = colorRamp,
        LowerColorStop = Convert.ToDouble(labels.Item1),
        UpperColorStop = Convert.ToDouble(labels.Item2),
        UpperLabel = labels.Item2,
        LowerLabel = labels.Item1,
      await QueuedTask.Run(() =>
        CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(ucDef);
        featureLayer?.SetRenderer(renderer);
    Requirements
