public Nullable<double> UpperColorStop {get; set;}
Public Property UpperColorStop As Nullable(Of Double)
/// <summary> /// Renders a feature layer using an unclassed color gradient. ///  /// </summary> { //Check feature layer name //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "U.S. National Transportation Atlas Interstate Highways"); if (featureLayer == null) { MessageBox.Show("This renderer works with the U.S. National Transportation Atlas Interstate Highways feature layer available with the ArcGIS Pro SDK Sample data", "Data missing"); } //Gets the first numeric field of the feature layer var firstNumericFieldOfFeatureLayer = "NumericFieldInFeatureLayer"; //Gets the min and max value of the field //Refer to the GetFieldMinMax function below var labels = await GetFieldMinMaxAsync(featureLayer, firstNumericFieldOfFeatureLayer); UnclassedColorsRendererDefinition ucDef = new UnclassedColorsRendererDefinition() { Field = firstNumericFieldOfFeatureLayer, ColorRamp = colorRamp, LowerColorStop = Convert.ToDouble(labels.Item1), UpperColorStop = Convert.ToDouble(labels.Item2), UpperLabel = labels.Item2, LowerLabel = labels.Item1, }; await QueuedTask.Run(() => { CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(ucDef); featureLayer?.SetRenderer(renderer); }); }
