ArcGIS.Desktop.Mapping Namespace / UniqueValueRendererDefinition Class / ColorRamp Property
Example
    ColorRamp Property (UniqueValueRendererDefinition)
    Gets or sets the color ramp be used to pick color for symbols from.
    Syntax
    public CIMColorRamp ColorRamp {get; set;}
    Public Property ColorRamp As CIMColorRamp
    Example
    Use Arcade expression to create Class Breaks
      var usaStatesLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
                     .FirstOrDefault(fl => fl.Name == "USA States");
      if (usaStatesLayer == null)
        return;
      await QueuedTask.Run(() =>
      //Create a color ramp from red to blue
      var colorRampForPopulation = ColorFactory.Instance.ConstructColorRamp(
            ColorRampAlgorithm.LinearContinuous,
            ColorFactory.Instance.RedRGB, ColorFactory.Instance.BlueRGB);
      //This Arcade expression categorizes the POP2000 field in the usaStates layer
      //into Low, Medium, and High values
      var arcade = @"if ($feature.POP2000 < 1000000)
                       {return ""Low"";}" +
                   @"else if ($feature.POP2000 >= 100000 && $feature.POP2000 < 5000000)
                      {return ""Medium""; }" +
                    @"else if ($feature.POP2000 >= 5000000)
                      {return ""High"";}" +
                    @"else{return ""NA"";}";
      //Create the Arcade expression info
      CIMExpressionInfo arcadeExp = new CIMExpressionInfo();
      arcadeExp.Expression = arcade;
      arcadeExp.ReturnType = ExpressionReturnType.Default;
      arcadeExp.Title = "State Population Categorized";
      arcadeExp.Name = "USA States Population 2000";
      //Each population category is assigned a color from the color ramp and symbolized on the map
      // using a unique value renderer
      var uvr_desc = new UniqueValueRendererDefinition()
        //ValueFields = new List<string> { "STATION" },
        ColorRamp = colorRampForPopulation,
        UseDefaultSymbol = true,
        ValuesLimit = 100,
        ArcadeExpression = arcadeExp.Expression
      //Create the renderer and assign it to the layer
      var renderer = usaStatesLayer.CreateRenderer(uvr_desc);
      usaStatesLayer.SetRenderer(renderer);
    Unique Value Renderer for a feature layer
    /// <summary>
    /// Renders a feature layer using unique values from one or multiple fields
    /// ![Unique Value renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/unique-value.png)
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      //construct unique value renderer definition
      UniqueValueRendererDefinition uvr = new
        //Refer to the function below to get a display field of the feature layer
        ValueFields = new List<string> { await GetDisplayFieldAsync(featureLayer) }, //multiple fields in the array if needed.
        ColorRamp = colorRamp, //Specify color ramp
      //Creates a "Renderer"
        var cimRenderer = featureLayer.CreateRenderer(uvr);
        //Sets the renderer to the feature layer
        featureLayer.SetRenderer(cimRenderer);
      //Function to get the display field of a feature layer
      static Task<string> GetDisplayFieldAsync(FeatureLayer featureLayer)
        return QueuedTask.Run(() =>
          // get the CIM definition from the layer
          var cimFeatureDefinition = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMBasicFeatureLayer;
          // get the view of the source table underlying the layer
          var cimDisplayTable = cimFeatureDefinition.FeatureTable;
          // this field is used as the 'label' to represent the row
          return cimDisplayTable.DisplayField;
    Requirements
