Public Function GetTasks() As IEnumerable(Of TaskInfo)
public IEnumerable<TaskInfo> GetTasks()
Return Value
An enumeration of TaskInfo objects.
var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault();
// if there isn't a project task item, return
if (taskItem == null)
return;
string message = await QueuedTask.Run(async () =>
bool isOpen = taskItem.IsOpen;
Guid taskGuid = taskItem.TaskItemGuid;
string msg = "";
try
TaskItemInfo taskItemInfo = await taskItem.GetTaskItemInfoAsync();
msg = "Name : " + taskItemInfo.Name;
msg += "\r\n" + "Description : " + taskItemInfo.Description;
msg += "\r\n" + "Guid : " + taskItemInfo.Guid.ToString("B");
msg += "\r\n" + "Task Count : " + taskItemInfo.GetTasks().Count();
// iterate the tasks in the task item
IEnumerable<TaskInfo> taskInfos = taskItemInfo.GetTasks();
foreach (TaskInfo taskInfo in taskInfos)
string name = taskInfo.Name;
Guid guid = taskInfo.Guid;
// do something
catch (OpenTaskException e)
// exception thrown if task file doesn't exist or has incorrect format
msg = e.Message;
catch (TaskFileVersionException e)
// exception thrown if task file does not support returning task information
msg = e.Message;
return msg;
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(message, "Task Information");
// TODO - substitute your own .esriTasks file
string taskFile = @"c:\Tasks\Get Started.esriTasks";
string msg = "";
try
// retrieve the task item information
//At 2.x -
//TaskItemInfo taskItemInfo = await TaskAssistantModule.GetTaskItemInfoAsync(taskFile);
TaskItemInfo taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
msg = e.Message;
msg = e.Message;
return msg;
// TODO - substitute your own .esriTasks file to be opened
try
//At 2.x -
var taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
// find the first task
TaskInfo taskInfo = taskItemInfo.GetTasks().FirstOrDefault();
Guid guid = Guid.Empty;
if (taskInfo != null)
// if a task exists, open it
//At 2.x -
//guid = await TaskAssistantModule.OpenTaskAsync(taskFile, taskInfo.Guid);
guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile, taskInfo.Guid);
else
// else just open the task item
//At 2.x -
//guid = await TaskAssistantModule.OpenTaskAsync(taskFile);
guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile);
// TODO - retain the guid returned for use with CloseTaskItemAsync
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(e.Message);
