ArcGIS.Desktop.TaskAssistant Namespace / TaskAssistantFactory Class / GetTaskItemInfoAsync Method
Full path to an .esriTasks file.
Example
    GetTaskItemInfoAsync Method (TaskAssistantFactory)
    Gets information about the task item stored in an ArcGIS Pro .esriTasks file.
    Syntax
    Public Function GetTaskItemInfoAsync( _
       ByVal taskFile As String _
    ) As Task(Of TaskItemInfo)
    public Task<TaskItemInfo> GetTaskItemInfoAsync(
       string taskFile
    Parameters
    taskFile
    Return Value
    A Task returning the TaskItemInfo of the task file opened.
    Exceptions
    ExceptionDescription
    Error opening the task file. For example the taskFile is invalid.
    Error opening the task file. The task file version is invalid.
    Example
    Get Task Information - from an .esriTasks file
      // TODO - substitute your own .esriTasks file
      string taskFile = @"c:\Tasks\Get Started.esriTasks";
      string message = await QueuedTask.Run(async () =>
        string msg = "";
        try
          // retrieve the task item information
          //At 2.x -
          //TaskItemInfo taskItemInfo = await TaskAssistantModule.GetTaskItemInfoAsync(taskFile);
          TaskItemInfo taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
          msg = "Name : " + taskItemInfo.Name;
          msg += "\r\n" + "Description : " + taskItemInfo.Description;
          msg += "\r\n" + "Guid : " + taskItemInfo.Guid.ToString("B");
          msg += "\r\n" + "Task Count : " + taskItemInfo.GetTasks().Count();
        catch (OpenTaskException e)
          // exception thrown if task file doesn't exist or has incorrect format
          msg = e.Message;
        catch (TaskFileVersionException e)
          // exception thrown if task file does not support returning task information
          msg = e.Message;
        return msg;
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(message, "Task Information");
    Open a specific Task in a Task File - .esriTasks file
      // TODO - substitute your own .esriTasks file to be opened
        try
          //At 2.x -
          var taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
          // find the first task
          TaskInfo taskInfo = taskItemInfo.GetTasks().FirstOrDefault();
          Guid guid = Guid.Empty;
          if (taskInfo != null)
            // if a task exists, open it
            //At 2.x -
            //guid = await TaskAssistantModule.OpenTaskAsync(taskFile, taskInfo.Guid);
            guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile, taskInfo.Guid);
          else
            // else just open the task item
            //At 2.x -
            //guid = await TaskAssistantModule.OpenTaskAsync(taskFile);
            guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile);
          // TODO - retain the guid returned for use with CloseTaskItemAsync
          ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(e.Message);
    Requirements
